Kuebeker
10 µW
- Joined
- May 13, 2015
- Messages
- 6
Hello
I'm a a tad ignorant on the subject so please forgive me.
Long story short, bought 2 motorcycle Ballistic batteries and both of them crapped out due to pour build quality.
I have enough cells to rebuild one and in order to do so I need to test all the cells before putting back the battery back together.
Testing my first cell I get:
The cells are A123 Systems ANR26650M1A.
The specs I found for my cells are 2300mAh 3.3v
The charger I have is a Skyrc ImaxB6.
To charge I set it to LiIO CC=3.0 amps CV=3.6 Volts.
When the charge is finish it stats 4.9volts. Is this normal?
When I read it with a volt meter it's 3.77 volts. Is this to much?
To discharge, it's set to 1.0amps at 3.10v.
It goes down to 3.01v @ 1803mAh for 108:19min. Is this normal.
Is the 2300mAh the max once it's completely drained or once it reaches it's discharge cutoff of 1.6v
Can the SkyRC B6 discharge all the way to 1.6v? If so how do I set it?
Any help is appreciated.
