ANT BMS CAN port pins?
Hi,
I only found a low res image of the ANT BMS communication pins (attached).
Does someone have a better image to share so I can be clear about the specification of each?
I couldn't find anything on Google.
Thanks,
LG.
Thanks for the reply :) I wrote to them and the good thing is that they replied the next day. The bad thing is that they wrote:
"the default version BMS don't have CAN communication and RS485 . . CAN communication and RS485 need to custom made before placing order". On their advert it does say this, with min order 100 pieces!
So useful to know -> bluetooth is the only option to pull data off it.
can you pls send the pdf of bms for PGN for can
Look at the post above yours
"the default version BMS don't have CAN communication and RS485 . . CAN communication and RS485 need to custom made before placing order". On their advert it does say this, with min order 100 pieces!"
