TobiasRipper
10 µW
- Joined
- Jun 6, 2016
- Messages
- 6
ATE 501.
After taking the scooter out from winter slumber, I noticed that the batteries are not charging. The Charger does not go into charging mode as indicated by it's charge light.
I tested the charger with a voltmeter, shows 56 volts. It has a power light and a charging light, Power light is always red and charging light is red while charging and turns green when charged or not plugged in to the scooter. I charged the scooter before storing it in the garage for winter. Are my batteries dead? I don't know what's the proper procedure for winter proofing your scooter so it looks like this lesson is going to be an expensive one.
If I plug the charger and turn the ignition, the dashboard lights up, horn works and the motor runs (tested carefully off the charger for the sake of seeing if electronics are in tact).
I am fairly certain there's something wrong with the batteries as literally nothing has been altered with the electronics components since I put it away last year.
