NeilP
1 GW
I have seen a few discussions about the use of AS5 on CPU's etc
AS5 manufacturer say that it is not conductive, but should be kept away from tracks/ traces IC pins etc as it may be capacitive.
Well without thinking I used it yesterday on the heatsink/ tape on the IGBT's (power output transistors) on my BMS battery alloy shell 2kw charger. I jsut grabbed the first tube of heatsink paste that came to hand
All readings I can make with a Fluke meter seem to show it is non conductive, and I have stripped and rebuilt the unit to check for stray wires but see none.
But the case gets a voltage on it with the AS5 paste.
Just stripped and rebuilt with normal white generic heat sink paste, and no voltage present on the case.
I only found out there was an issue when I got a jolt off the case. I plugged it in ot the mains power and as I did so I touched the outer case of the brushed stainless steel wall socket, while the other had was n the alloy shell case. I got a nasty jolt.
I still not 100 % sure it was the paste, but cant see any other cause.
