Sharkboat
Astro Flight motors have been shown to work well on e-bike applications. They have a high resistance to heat and are up to 93% efficient. However, this is only the peak efficiency and is usually achieved at about half of the low end of the typical power range. For the 3220, this is 2000 Watts. At very low power, the efficiency drops off rapidly. Running a very high voltage/ high rpm is one way to increase the range of power that the motor can run above 90% efficiency.
My goal is to have an ebike that runs at above 90% motor efficiency for most or all of the time. This will allow the motor to not overheat, increase the life of the motor and motor controller, have a longer range, and use less batteries.
The 3220 is twice as powerful as the 3210. The other option is the custom Matt Shumaker 3230 motor, which is 50% more powerful than the 3220. This motor would achieve peak efficiency around 3000 Watts.
http://endless-sphere.com/forums/viewtopic.php?f=28&t=18681
The 3230 would have the same power as a 3210 and 3220 combined. My theory is that using a 3210 and 3220 combined would be more efficient than the 3230 alone.
The gear ratios and many other factors complicate this question.
Does anyone have additional information about improving the efficiency of an electric drive system, or know where I could find the information online?
