ammodave said:
Care to recommend another motor? What's your advice on the rpm issue?
It would be best if you explained why you thought about a 350w motor. Is it for increased speed or what?. It's always better to clearly state what you're trying to achieve rather than what bits your thinking of buying.
Those forks do look a bit spindly for a high torque motor. Getting the right speed is the hardest part as the 201 rpm motors for 26" wheels are normally too slow, and the high-speed versions for 20" wheels are too fast. The BPM motors come in a whole range of speeds, but it's not easy to find someone supplying the middle-speed versions. Your 28" wheels will give a top speed of about 19 to 20mph with a 201 rpm motor. The 328 rpm motor will try to do about 31 mph, but it doesn't have enough power for that,so it'll be very inefficient.
You can get more speed by using higher voltage. A36v 201 rpm motor will do about 24mph with 12S lipos at 48v, but lipos aren't plug-and-play, so you need to look-up how to use them. You can make your own bottle battery out of plastic drain-pipe and a pair if 5000maH lipos, which should easily do 10 miles if you don't have steep hills.
If you want light-weight, then the Q100 with 12S lipos will be a good solution, but if you want a motor with some grunt for hill-climbing then the Bafanf BPM or CST rear motor is a good solution. If you want to spend more money, there's loads of other motors, but I'm assuming you want an adequate low-cost solution.
Those ready-made bottle batteries can't supply enough power unless your happy with 15mph and a 250w motor at 15 amps or less.
Some of the Bafang 250w motors might also be good for you. Greenbike kit do the SWXH in 260rpm, but you have to build your own wheel. They'll do it for you, but it'll slow down your order.
http://www.greenbikekit.com/index.php/swxh.html
If you have a look on Alibaba.com, there's now loads of 250w motors with cassette splines now, but they don't seem to have found their way to suppliers that sell single items.
