RustyKipper
Hey guys,
As per the tittle I need to service the freehub on my 500W CST hub. It goes through spates of slipping really badly which is a bit worrying as if it fails completely I have a 5 hour walk home from work, or if crossing a freeway I will come to a sticky end.
If I spray penetrating oil down behind the cassette this helps and I can hear the ratchets working again.
I have seen somewhere that removing the two lock nuts within the end of the cassette spline should allow the freebub/spline to pull out but its solid and wont budge, I've tapped it lightly with a hammer but still no joy. It took me a good 10 minutes just to break the actual back wheel free of the frame due to steel/aluminium corrosion so is it possible something similar is occurring with the freehub? Does it maybe just need a bit more 'persuading' with the hammer? This is clearly one of those things that once you have carried out the operation once it is obvious the next time.
Many thanks.
Many thanks.
