SackofFluor
- Joined
- Jun 26, 2021
- Messages
- 10
ahh, so much information
well then i will first sit down, calculate the average, median and std.
Discard cells that are too low (shall i keep "too" high cells) and then do proper "mixing".
Yes I will be using a Daly smart bms and thought to stop charging at 4V and discharging at around 3.3/3.4 V , I thought this would give me relatively good safety margins.
Regarding the architecture I think i will have to see what kind of setup can be build well and stimm remains somehow scalable.
I was thinking about spot welding thin nickle strips to the cells and attaching those to a copper bus bar using my WIG welder.
The nickle strips i was thinking about 5mm, 0.1mm, they should be able to survive around 2-4Amps and work therefore as a fuse.
But because i wasn't sure, i also ordered fuse wire
