modern_messiah
Hi all,
Although I am currently in the process of building my own low power coreless axial flux motor from scratch as a test I am, like most people, already thinking of bigger and better things. But I have a few questions looming large that have me scratching my head. I have theories – but it’s always nice to hear others opinions before jumping in the deep end. The only thing holding me back thus far was making a complete ass of myself – time to bite the bullet and have faith in the anonymity of the internet. :wink:
So here goes!
1) If a hub motor was mounted directly to the wheel (so a 1:1 ratio between motor and wheel rotation), is the speed of the vehicle merely limited by the maximum rpm of the motor, given various other factors such as the torque required to maintain velocity, heat generated and power required? The way I see it, electric motors are (depending on design of course) capable of rpm’s much higher than any wheel would ever be required to spin.
2) Naturally the higher the rpm a motor can achieve, the less torque the motor is able to produce? Having large gaps between magnets on the rotor or between teeth on the stator will result in lower maximum torque, but should result in higher achievable rpm?
3) Further to point 2, if a designer was after higher rpm’s they would have the rotor moving further with each phase shift – so larger distances between magnets (less magnets if you will). If you want more torque, the rotor must move shorter distances between phase changes so there would be shorter distances between magnets (more magnets). The same effect could be achieved by reducing/increasing the number of stator teeth instead.
4) Is having more coils on the stator a detriment to the design in any way other than increased heat? I’m assuming more coils will consume more power in order to produce more magnet fields. Why not build a motor with for example 30 teeth and only 4 magnets? Obviously the more magnet pairs you introduced the more torque the motor will produce but the slower it will be able to spin.
Pretty much every question above will result in palm-to-face like reactions, and even though I believe most them are fairly self explanatory when you think about the way a BLDC motor works, but I’m the kind of guy that always second guessed himself on university exams.
So yeah, any insight and clarification would be very cool.
Regards,
Matt.
So here goes!
Regards,
Matt.
