SlyCayer said:
Thank you clarifying.
You do not suggest I use your system as LVC/Balancing Unit, even with a contactor/relay? I undetstand what you mean by the LVC would go back on and off on and off and that is a problem. But don't you think we could find a way to have a switch that is moved from on to off at the same time that must be put back to on before the Contactor/Relay is turned on again? Something like a Magnetic Toggle switch which can be put on by the user and then as soon as the power is lost, the toggle goes back to off and must be manually put back to on?
Yes, you could drive a contactor easy enough, and you could probably do some sort of latching setup that has to be reset, but think about the situation where your pack is close to the end of capacity and you are starting off from a stop. Do you really want to have it cutout completely while you are stuck in the middle of an intersection? The way our normal LVC function is used with most typical setups is that when a cell's LVC trips it is like pressing a momentary pushbutton. As soon as the load is removed, the cell's voltage will always recover back up close to the nominal voltage. When it does, it releases this "pushbutton". In reality, these are really pushbuttons, but optocoupled electronic switches. All of these opto switches are wired in parallel so that any one LVC circuit can "turn on this "switch". Anyway, this combined switch is tied to either a dedicated brake input on the controller, or to the throttle signal itself. Basically, what happens is that throttle signal is temporarily cutoff, by grounding it, for as long as the LVC is tripped. This removes the load on the cell. It usually takes about 1/2-to-1 second for the cell voltage to recover and then the pull-down of the throttle is released. If you keep on the throttle, it will "hit" again, and the cycle repeats. This happens at roughly a 1-2Hz rate, and it definitely gets your attention. Usually, if you back off the throttle a bit, it will reduce the load enough to allow you to continue on at a reduced power level. In most cases, with the chosen LVC set points, you can have as much as 10% capacity left at the time the first cell hits the LVC point. At the end of capacity, even the slightest throttle will cause the 1-2Hz oscillation.
My point is that given the way individual cell LVC circuits work, you probably don't want to be cycling a main power contactor at a 1-2Hz rate.
You also don't want to simply kill power, that then needs some sort of reset procedure, at the first LVC "hit". For larger EVs, I think a nice, loud, audible alert is probably a better idea. Another possibility is maybe reducing the throttle 50%, instead of pulling it all the way off.
-- Gary
