safe said:...so it's a good idea to charge up in the morning, go for a ride, then just leave the bike uncharged overnight. (don't let the charge go too low though)
They last about as long as an average American marriage. :lol:Toorbough ULL-Zeveigh said:It seems like lithium batteries require almost as much maintenance as a woman.
I've read somewhere that it's really all about voltage, the higher the voltage the cell holds the faster it degrades. A123 have found a way around the problem by creating a cell that keeps the voltage low all the time and the result is longer life. So a more accurate way would be voltage.fechter said:Is that relationship valid for all lithium chemistries? I assume they're talking about Co based cells. It may be entirely different (or not) for LiFePO4 or LiMn cells.
OneEye said:Supposedly it will have a 5-10 year shelf life/service life regardless of state of charge. If true that would be awesome.
OneEye said:Obviously anything on the Chevy Volt is somewhat speculative, but I thought the reason they intend to keep the SOC between 30-80% is it extends the cycle life (as opposed to the shelf life) of the cells. Dicharging and recharging alter the cathode and anode at the microscopic level, leading to cell degredation; deep discharges/full recharges do so to a greater extent. These changes are a different phenomenon than the propensity of most Lithium chemistries to self-degrade simply in a storage (0-cycle) mode.
safe said:Should it matter?
Yes is does.OneEye said:If the LiFePO4 chemistry is (not) (relatively) shelf-stable at a high state-of-charge, the price-weight-range-cycle life-shelf life optimization decision e-bike builders/buyers/users have to make changes dramatically.
safe said:If the Chevrolet Volt has plans to do a 30% low and 80% high pack range then they are likely onto something. And they are also planning to use A123 cells. So unless there has been a change in philosophy (which is possible) I'd tend to think that higher voltage always makes things worse. Even the older Lithium types are okay if kept at low charge and low temperature for long periods.
