DrkAngel
1 GW
I've been sadly disappointed with any BMS\PCB\PCM that I have tried, $40-$60 range.
"Balance" is typically a trickle bleed-down of the over voltage cells.
I am presently investigating a recent observation.
On a recent purchase of old, setting for years, HP notebook packs, I noticed that all cells in each pack were precisely at the same voltage.
All packs had different voltages, but every cell in each pack was precisely balanced to the 1 hundredth of a volt.
Logical and most likely explanation is that the built in bms type board was maintaining balance ... without any external power!
Theoretically, overlapping 3 of these across the 7s of my 25.9V builds should maintain, or attain, a voltage balance between all cells.
I would not charge or discharge through these controllers, merely allow them to do their thing ... as they have been for these past many years.
This should simplify bulk charging and keep it much safer!
