markz
100 TW
I need to know what the difference is between a sin wave controller and a square wave controller that are both an option for the Q11 kits.
S12P 750Watts Torque Simulation Square Wave Controller for 36Volts and 48Volts battery pack E-Bike System - $29
S12S 500Watts Torque Simulation Sine Wave Controller for 36Volts and 48Volts battery pack E-Bike System - $34
This note is on both of them,
"This kind of controllers are not as same as the other commom controllers. It is the torque simulation controller. So when you change the level of the PAS by LCD or LED panel, the speed will not change. They are in same speed. But the torque is different. In other word, the output of controller power is different."
Someone mentioned on this forum that they liked the 500W KU93 Controller because of its lower power but the KU151 is rated for 1KW. I just assume I stay away from those Torque Simulation bcuz it mentioned PAS.
Looks like I will have the wheel/motor $114, controller $31 and S/H~$100. Should I buy the batteries and charger from bms or hk?
