I have the positive and negative wires connected on the plug that goes from the motor assembly but the yellow and green wires have broken off. Can anyone tell me what pins the wires go to? Thanks in advance :thumb:
There seems to be the part that goes to the battery only. Normally there would be a charging port and at 90 degrees away there will be the part that the battery connects to.
I tore it apart a bit further. It is called a frame mounted battery cable. I need to know what number contacts in the picture that the yellow and green wires go to.
