fabieville
- Joined
- Jul 15, 2012
- Messages
- 114
After I installed the bottom bracket, the chainring and the crank arm, I turned the chainring by turning the crank arm. I found that the chainring was wobbling from side to side and this will cause the chains to come out of the chainring sometimes. But when I just turned the chainring by spinning the chainring only (crank arm not moving), the chainring was not wobbling. I guess this is because the spindle of the bottom bracket is warp (not straight). Am I correct? Or is this normal for all bottom bracket conversion with freewheel capability? How can I prevent this?
