That's cool. How did you wind the coils so neatly?
I can imagine you might have a problem with the coils flying off at high speed.
It may work better with iron in the middle of the coils.
Most motors also have 'teeth' on the armature poles that cover over part of the coils so there is only a small gap between teeth. Any teeth or iron inside the coils needs to be laminated or otherwise electrically non conducting. Your steel shot/epoxy mix may be good.
Now think about the next step which would be to make a brushless version. :wink:
