Building an EV battery pack from 2000+ of a leading brand of 18650 li-ion cells, available at a good rate.
So far, the plan is to use a 6S20P layout per module, with 18 modules in total = 108S20P
Nominal pack totals: 400V, 250Amax, 24kWh
For the module BMSs, 6 readings each(1 reading for each 20P).
This would require a board of 4.1Vmax 300Amax per string, or 25.2Vmax 300Amax total per board.
So, the question is
Where can you buy a 6S BMS/shuntedPCB capable of 25.2V 300A?
Thanks in advance
So, the question is
Thanks in advance
