A1234LIFE
Hi all,
I have been riding an electric bike for about 6 months. It was built from a Crystalite kit. You can see more about it if you follow this link.
http://home.comcast.net/~steveandbeck/ebike.htm
I just stumbled onto this site and was very impressed. I noticed a name from my R/C days. I actually got great advice about bikes several months ago from Gary Goodrum on the ezone forum.
Anyway, I am working on replacing my 48V lead setup with a 15s4p pack of A123's. After reading through some of the information here, I am thinking about taking all the cells apart and creating 1s4p packs. They would be flat packs with 4 cells side by side, using equal lengths of 16 gauge wire to connect the four + terminals to a 10 gauge piece of wire for the main lead. Same process for the negative terminals. It seems like 16 gauge should be enough for the parallel connections, since I don't expect to draw more than 10 amps per cell. My controller is the 4840, unmodified. Using APP connectors, I could easily put the cells in series to create my 15s4p setup. I will probably build one more so that I have a 16s4p pack and just charge the entire thing with a 48V Lead Acid charger. If I stick with 15 I have a Schulze charger that will do the job. I really like this design, because I can easily disconnect the modules and charge the 1s4p packs individually to keep them balanced. It also makes it easy to add more voltage by just adding another 1s4p pack in series once I modify my controller.
Any thoughts on my plan?
Thanks,
Steve
Thanks,
Steve
