BYqSXt8Z
Hello all! First post.
After reading a lot and not finding all that much about specifically using the P108 Ryobi 18v 4AH batteries to make a pack (except for one thread where someone mixed it with greenworks batteries http://endless-sphere.com/forums/viewtopic.php?f=14&t=56505), I decided to just go for it and document it here! *edit* I have since been discussing the use of these batteries with bluovalguy on his thread and running other side tests if you want to know more about these.
So here is my setup:
-4x 18v 4AH (2x2 series/parallel); cost 99$ for the first pair and 129$ for the second (average 57$ a peice)
-4x ryobi fuel gauge as the connector (sale for 12$ each) (actually 6 of them because of the sale, but only using 4 of them at this moment)
-*** this step is done, gear updated***a Strong branded bike with SLA battery (the thing weighs over 40kg) that I got used. It certainly gets the job done, but I would like to eventually be able to use my regular commuting bike as electric OR bare with no extra weight, so I hope that in changing parts slowly I can get a setup I like and then transfer it over to my normal commuting bike as a front-wheel drive once everything is ready.
-***new setup*** I am now waiting for my outbound 02 motor from ebikes.ca; I will mount it in an alex rims DM18 with a wide tyre to add traction, with the computer and 20 AMP controller, on a Kona dr. good with 8-speed nexus hub in the back (so the bike I've been commuting with for a few years).
Why this setup? Simple, I can't get this many reliable cells that I don't need to solder (soldering aluminum is too sketchy on the cells, I don't like it) for this cheap, and it is also hard to get readily available chargers and extra packs if one cell dies. This way I only need to replace 1/4 of the pack at a time if a cell is defective, and I can easily keep chargers at work and at home if I need it (for now I have 3 at home already). Not only that, but since I use lots of these tools, I also have spare 1.2AH batteries laying around if I want to go super light-weight for short hauls (or just one pair of the 4AH if I want that). It seems like a very flexible and affordable option. So far I have spent under 300$ on the pack, and the chargers just came with my tools and a spare would be easy to get (60$ for the 6x charger if I go cross border shopping).
Progress:
July 3rd
-So far I have made the connectors for the batteries. Sometime this weekend I hope to take the bike out for a ride.]
-I used the fuel gauges based on the recommendation of bluovalguy, and it works. I can measure the voltage just fine when the fuel gauge is on, whereas this is not true when I try to measure the battery directly (as had been reported by bluovalguy).
July 4th
-No-load test in the house successful (the bike upside down).
-The batteries normally turn on properly, but as I played with the harness and put and removed the batteries multiples times, every now and then a battery did not "sync" (as bluovalguy had put it). I can't replicate the issue and it seems to move around, but simply removing the batteries and putting them back in fixes it.
July 5th
-The pack is now built and fully secured/ready to use
- Took it out for a very short spin (1 minute), packs some puch! What an upgrade over SLA!!!! Now all I need is an endurance test (well along with making a proper bag for the batteries because yanking them out of a backpack by the wire harness is only going to work a few times
July 16th
-got the parts, ordered new rim, waiting for the rest of the parts for assembly.
More to come!
Progress:
July 3rd
July 4th
July 5th
July 16th
More to come!
