Bigbikebob
After completing couple of e-bike builds and a lot of troubleshooting I feel it's a good time to start looking into building my own battery pack drive the cost down. I feel I read enough to start asking questions
from what I understand there are variations of lithium battery chemistry.
Lithium Cobalt Oxide(LiCoO2) marked as ICR, LCO, Li-cobalt
Very energy dense. Can provide amps very fast due to low internal resistance which can be bad if things go wrong (they go wrong quickly). And has a short lifespan.
Lithium manganese oxide(LiMn2O4) marked as IMR, LMO, Li-manganese
High power and safety but less capacity then LiCoO2
Lithium manganese nickel(LiNiMnCoO2) marked as INR, NMC,
Which is more stable then the LiCoO2 and more energy dense then the LiFePO4
Used by some electrical cars and the zero motorcycle. This chemistry balances the pros and cons of LiCoO2 & LiCoO2
LiFePO4 marked as IFR, LFP, Li-phosphate
Is a very stable chemistry medium electrical density and has a long lifespan.
What is interesting is that Tesla uses:
Lithium Nickel Cobalt Aluminum Oxide (LiNiCoAlO2) marked as NCA,Li-aluminum and NCR (for Tesla blend) for its cars and home battery, it is less energy dense then the LiCoO2 and safer but not as safe as the LiFePO4. So why go with LiNiCoAlO2?
So far so good?
For the more practical part of this post I would like to know:
1.Are there any other cells I should consider?
2.What I a reliable place to purchase battery cells?
3. I came a cross the Headway LiFePO4 and like the idea that you don't have to solder them but how is the conductivity when using such solution?
So far so good?
