Hi all,
I'd like to present my next battery building project which consists of a modular pack having modules each having 36P cells.
The cells i'm using are Samsung 29E, each 2850mAh. So each module will be 3.7V/102Ah.
I previously did build a pack with the same cells for my Vectrix electric motorscooter. That pack was also modular build with 30P cells, 36 modules.
So a serious pack with 150V and 85Ah, maximum current is 240A causing serious thoughts of busbars, connectors etc.
The pack im building now is for my CityEl 3-wheel 'motorcycle' kinda thing...
Design considerations:
The modules will be put in battery size boxes custom-made of RVS steel frames covered inside with lexan plate and insulation.
Size of each box will be similar (or smaller) to 100Ah SLA car batteries like 170mm wide, 325mm long and 210mm height.
My boxes will be a little bit higher then this standard size to accommodate the stack of 12cells high, 250mm.
Each box will have 8 modules like 4S2P so its actually 4S72P and delivers 14.8V and 205Ah. Double the density and halve the weight of the SLA lumbs.
Inside each box will also be a BMS board which communicates over CAN-BUS with the other boxes, dashboard etc.
I will add some pictures and the buildup process next.
Paul
Paul
