PARADOXICLES
- Joined
- Dec 24, 2012
- Messages
- 38
Hello, im in the process of building an ebike, this will be my second electric vehicle ( the first was a power wheels when i was a kid). i have been doing lots of research, which led me here, and i think you might just be able to help, i have lots of questions, some im finding as i search the forums. some i have yet to discover... i guess i will start form the beginning cuz there is alot
I have a 21 speed mountain bike i am converting to an E bike. after many weeks of research, i found a kit seamed pretty much perfect for reaching my goal. i bought a 48v 900w duel motor mid mounted kit from gngebike.com out of hong kong. here is a link the the specific product page for the item i bought.
http://www.gngebike.com/900wbrushed.htm
http://www.ebay.com/itm/48V-900W-2-MOTORS-brushed-MID-DRIVE-ELECTRIC-MOTORIZED-E-BIKE-CONVERSION-KIT-/200722109114?pt=LH_DefaultDomain_0&hash=item2ebbf852ba
it seams their site has more pics, and the ebay page has more info.
i have high hopes for this kit, it appears to be of good quality, but there was a problem no one could foresee of my bike having an overhang in front of the bottom bracket, which causes the motor mount to not line up properly with the bottom bracket, i plan on cutting the over hang section of oval tubeing off to create a nice flat edge that lines up with the bottom bracket are, this shouldnt significantly effect the structural integraty of the bike as it is over hang, but if it dose i have a few ideas to reenforce it including having reinforcement professionally welded on. ( just thought i should mention this part of the project so others can know of these problems as to avoid them or prepare for them)
and of course as with everything these days, it dosnt come with batteries.... which is where my first question comes in. how do i know which batteries are best to buy? the manufacturer's info is very confusing, and seams to be missing the info about my model ( all pages seam to have a general description that covers most their models) this is the info they provide.
"2.What battery is recommended for this kit?
If the kit is 24V, you need two 12V batteries, (lead acid or lithium), or one 24V battery.After they are linked together,
the minimum capacity should >12AH and recommended>20AH
If the kit is 36V, you need three 12V batteries, (lead acid or lithium), or one 36V battery.After they are linked together,
the minimum capacity should >12AH and recommended>25AH
this dose not mention my 48 volt kit, or its needs, and communicating with the manufacturer is not getting me answers due to the language barrier. i want to make sure i get the maximum power possible, with out over powering the motors, as well as the largest charge possible ( for maximum riding range). i am also looking at wiring the batteries up with a selector switch to switch between a parallel and series wiring to witch between riding and charging ( oh yeah, a charge will be wired permanently in to the set up as well so i can charge anywhere i need)... if my idea works, this should allow me to charge the 4 batteries as if they were one big 12v battery, but still use them for riding in the requered 48v set up, all with out removing the batteries. i am considering using batteries similar to these... depends on what i find
http://www.batterystuff.com/powersports-batteries/LFX09A2-BS12.html
will these batteries work for my needs? also, if you have any recommendations for better, or more affordable batteries, i will gladly look into them.
the next stage of my build is i would like add in solar pannels, probably on the battery box which will be mounted on a rear seat rack. if possible, i would like to even create some custom made solar hubcaps ( not using that space is such a waste, and would provide a big area for collecting sunlight)....how do i figure out what specs are required to properly change the batteries?
the last stage of my project is to arrange an array of batteries and panels in a trailer for even more range, and maybe to even haul a bit of camping gear or something.
i know there is alot to take in here, but any help would be GREATLY appreciated. thank you!
