The simple answer is: if you're going to buy a single inexpensive charger, stick with a 3 A model. If you consistently charge at a higher rate to full state-of-charge, your battery won't last as long.
If you step up to something like Grin's Satiator, you could progam multiple profiles, and use a 3 A profile most of the time, but also program a higher-rate profile that only goes to 80% SOC for when you need to dump in a bunch of charge quickly. Or do the same thing with two cheap chargers, one for slow full charges and one for fast partial charges.
500 W would make me uncomfortable, and 1,000 W sounds nuts for this battery. I wouldn't go higher than 8 A for the fast charge. Which, as I said, would only be used rarely and not for a full charge. As wesnewell mentions, your BMS charging limit may not even allow that.
