hi...
here's the thing,
i have tektro e-sub disc brakes, which use magura mineral oil, since i don't want to use 2 different oils i thought about getting magura front disc brakes. (m2) problems is that it doesn't stop very well. so i read that shimano also uses mineral oil, but someone told it's not the same viscosity, and it will leak.
another thing, does anyone know if the tektro e-sub have different brake pads (better ones) then stock? http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_1008467_langId_-1_categoryId_273955
one last thing, i heard there there's some sort of an adapter you can connect to any discbrake which can be used to connect to an e-brake, where can i find sucn a thing? is it easy to install?
here's the thing,
