I have a POS 90's ford that has a bad alternator. I have heard that when your alternator is bad it will drain your battery. That is the issue I have. Before the alternator would work but would drain the battery, now the alternator does not work and still the battery drains. So what would cause this in the alternator? I assume the brushes are good because the battery draining was before and after it failed. Or maybe just buy a used alternator? I would rather just repair it myself for ease of mind that I know everything inside of it is perfect and will not fail again, and not buy a new one for more then the car is actually worth.
