Holz2010
Catrike Trail. Ping 48V 30Ah double pack. Crystalyte 5305, Methods Modified 100V 100A 18 fet Controller. Lots of hills in Blacksburg, Virginia area. Lots of fun! The flags and lighted whip dork it up a bit, but it's visible!
I'm afraid that Doctor Bass' KMX trike is way out of my league -- 70MPH! -- Yikes!chvidgov.bc.ca said:I'd like to see this go head to head with DocBass'es badass KMX! He's probably running higher voltage, but the Catrikes are lightweight...hmmm....
To be honest, I have never tried to adjust it. The stability with my Trail even at high speeds is good, so I haven't messed with it. Ideally it should be about 1/16".chvidgov.bc.ca said:Oh well...if I see you on the road, I'll pull over and let you by...I'm just pushing a 9C at 48Volts on my Actionbent trike. I've hit a max speed going downhill at 43mph...just can't seem to go any faster without more hill. Just curious how much toe-in you are set to. I find my other trike, the Catrike Road, a bit sensitive steering-wise. I think I have +1/16 inch toe. My Actionbent is set to zero.
Well, I do look at the accumulated Regen reading on the CA at the end of a trip, and it is giving me regen. (Also I can see the current shift at lower speeds as well when I hit the regen button, but there is a less abrupt braking effect at lower speeds - so no skid.) But you're right, running down a steep hill at 40+mph, its not what I am focussed on. Don't think it would be shorting of the phase wires just at higher speeds...but I will do a test of that. Off to TN for a bit -- but unfortunately, not on the trike.tjason said:Hi Barry,
In response to your leaving a patch when you use the regen brake; I realize that at that point you're busy watching the handling of the trike but by any chance have you noticed the regen current reading on your cycle analyst at that time (during regen braking)? My line of thought is that perhaps it isn't regenerating at all but just shorting the motor phase wires together. The braking effect would be similar but very strong compared to regen. I don't know if this is possible with the design of your controller and still allow it to propel you forward but since re-programming of the regen level didn't change it that much (at all?) I thought this might be a possiblity. You could also test this when going slow or with the rear wheel propped up and just pedaling against the regen to see if the current is actually getting back into the battery. I am probably talking out my butt because of my limited knowledge of the controller operation but, just a thought.
Terry
And thanks again Terry!Holz2010 said:Could not have put this together with lots of help and guidance from tjason, and support from methods and ebikes.ca.
