Cell Size ?
jmygann
What is the LiFePO4 cell size that most are using ?
are these larger ? http://tinyurl.com/68g2sm
" Lithium Metal Hydride ? " wtf is that ?
anyways.. C-LiFePO4 40138 cells are 40 x 138 mm ( 40mm diameter.. 138mm long )
5.4 inches long.. but then add the threaded bolts and you get 6.75".
Green " lifebatts " or older stock.. or whatever version of the story you got. No matter.. decent cells but at 158 + shipping.. no charger no bms = 40 $ per cell.
And is that the size that Ping and others are using ? ....
Example ..
http://tinyurl.com/5jul52
