Change from 8S 33v lipo battery setup to 36v LiFePO4
mjp8081
San Francisco Bay Area
So my eMTB uses 2x parallel Turnigy TrackStar 200amp ESCs, both labeled "34v max" on the side. I was thinking about switching to a 36v LiFePO4 battery. The 2 extra volts, probably wouldnt be a problem, but a fully charged 36v LiFePO4 battery actually maxes out at 45v or something like that. I'm assuming that would be a problem, right? ESCs dont have built in voltage regulators to handle that voltage, do they?
So I was looking at regulator buck boards on eBay, but I dont think any would handle the current.
Whats a good solution? --thanx
Hi
As I do not know what MOSFETs are used in the ESC I cannot say whether it would work or not. There is no voltage regulator on the input though.
34V max would cover a fully charged 8S lipo battery (33.6V) but I would not risk it at 45V which is over 30% of the max rating.
Putting a step-down voltage regulator in front of the ESCs would, in my opinion, not really be a feasible idea. As you have already seen such a device would have to handle the current drawn by both your motors and that would lead it to being a pretty large device, either with pretty large heat sinks (linear) or with with switched mode - which is basically a form of ESC before your ESC. Either way not very practical.
I am afraid with your current ESCs not really a good option, in my opinion, to switch to the 36V LiFePO4.
Thanks wee--yeah you might be right. I know there must be some sort of electrical solution to the problem, some sort of voltage reducer/limiter circuitboard that can handle the high current/amp draw. I am just ignorant of how to do it, but I imagine it would be too bulky or expensive.
I did find an interesting product line of ESCs, including a "dual" motor version, that advertise handling a wide range of input voltages (12V to 65V). I am waiting to hear about prices.
http://www.fliermodel.com/en/products.asp?bigclass=87
Hi
Oh, it is not a hard thing to do electrically. Linear and switched mode regulators are common - just not practical in your case.
The ESCs you mention can also be bought here:
http://alienpowersystem.com/product-category/esc/
The Flier ESCs do not have a great reputation though. You may be lucky but be warned.
