theyerb
I had a humbling experience today trying to put together my first battery pack made from 20 matched Konion cells in a planned 2p10s configuration. My soldering skills are... two weeks old. After a while, the super glue on my bench was looking appealing, so put a batter bar between two cells and then applied super glue to the sides. The capillary action between the cells and bar allowed the glue to seep nicely into the space between. The idea was that as long as the bar and battery were in contact, the glue would merely keep them from being pulled apart, and not for any conductive purposes- of course,super glue has none. It seemed like a great idea: bypass heat-inducing methods, it is really quick, no damage to the batteries, probably cheaper.
It didn't work. The capillary action worked its way between the bar and cell and lifted them apart ever so slightly, even when using a clamp with pressure.
My next idea is to use conductive glue. These types of glue are typically an epoxy with a metal powder mixed in such as graphite. Some of the glues have resistances of about 30 ohms per inch. Is that a lot? Do you think this is an idea worth looking into?
