fechter said:
On the cooling fans, they are likely brushless motors that have the controller built in. You can reduce the voltage going to these to slow them down. Your speed control kit may not work properly driving a brushless motor, but I don't think it would hurt to try it. With fans that small, you might get away with just a big resistor. You could also wire the two fans with a series/parallel switch to run them at half speed.
Thanks!
I was incorrect about no label on the fan motors...sorry.
When I looked through my photos I found that they do indeed have stickers on them. At the time I had the fans (or more correctly the "impellers") out of their housing, there was a lot of other stuff going on around me. I quickly took some photos, put them back together in a rush and stored something like: "cannot make sense out of the label" in my memory...and that memory changed later into "there is no label"!
Well, here are the pictures:
And here a datasheet: http://charcroft.com/site/pdf/data/mftr_data/comair_rotron/Comair%20Rotron%20Diplomat%20Motorised%20Impellers.pdf
It is the DD523612B1A , with an added "X" behind it: DD523612B1AX , whatever that might mean.
They describe the motor series as:
"The Diplomat® Product Family is constructed using Brushless, Electronically commutated DC Motors, giving excellent control whilst minimising electrical noise."
That's another way of saying: "Built in motor controller", right?
What would be the most promising approach to try to control the speed of these impellers?
I am envisaging something like this: A thermistor in the intake airstream and another thermistor in the exhaust airstream. If the temperature is equal (or intake is warmer than output), then the impeller speed should be so low that it just allows a bit of airflow to keep the temp measurements accurate. If the exhaust air is a lot warmer than the inlet air, then the impellers should run at maximum speed.(I don't need to worry much about cold air where I live, but in cold climates it would probably be best to turn the impellers off altogether when the battery temperature is below 16°C or so.)
In the datasheet linked above it also says:
The following can be independently or collectively added to the basic product offering:
• TTL or Open Collector Tachometer Output –
• Discrete Alarms –
• Harness Assemblies –
• Speed Control – Via thermistor, voltage or Pulse Width Modulation, the speed of the blower can be
controlled, to minimise noise and power consumption.
I hope this is not too fat off topic - sorry if it is. Let me know, then I'll start a new thread for this impeller taming project!
