Hey Endless-Sphere,
I came across my first problem on my new electric longboard that I cannot figure out.
At first, setup was working perfectly! I could ride around with ease. This only lasted for an hour or so though; then, my motor would stall and make awful noises as soon as I stood on it. I thought for sure it was an issue with the motor, until I kept playing with it and found out that my gear that was on the shaft that connects the belt to a timing pulley on the wheel was the issue. The wheel spins with ease when it's in the air, minor issues occur when on the ground, then it all fails when I stand on it. The gear is connected to the shaft by two tiny set screws that get screwed in with a hex key. What I am thinking is that as soon as the motor has to provide enough torque to power something heavy (like a 110 pound girl xD) it works too hard on the shaft that it forces it to slip a bit. My conclusion is that I need a better way to mount the gear to the shaft. Those tiny set screws are basically stripped at this point so I am in desperate need of solutions.
Extra info:
Motor: Turnigy Aerodrive SK3 - 5055-280kv Brushless Outrunner Motor (hobbyking)
Gear: http://sdp-si.com/eStore/Catalog/PartNumber/A%206A25M014DF0906
Batteries: http://www.ebay.com/itm/2X-ZIPPY-5000mAh-7-4v-2S1P-2S-20C-30C-LiPo-RC-FREE-EC5-Traxxas-Dean-HXT-ADAPTER-/121429145474 (in series)
Thank you so much
Amanda
Extra info:
Thank you so much
Amanda
