A..dam
1 W
Got the kit from BMS and I am beginning the assembly for testing.
I need your help with figuring out connections coming out of the controller S06P. (Most of them were easy, because colors of wires on male AND female connectors are the same) But couple of female connectors have no visible wires and I do not want to cut the sheath to experiment)
1. There are 2 male small plugs with 3 wires:
Black plug has brown, yellow, black wires.
White plug has red, white, black wires.
Which plug is for speed sensor and which one is for pedal PAS sensor?
2.What is the purpose of the small black male plug with 2 wires, black and blue?
3. Also any wisdom on mounting the "hidden wire sensor 2" from King Meter with a red LED?
4. Finally the motor. I have ordered Q75 on a 20 inch wheel in 201 rpm. Had to wait extra month as BMS did not have 201 in stock. Motor has no marking indicating much except sticker 26 inch (presumably lower speed, hence 201) and on a side a plastic cap has small letters CHZ 600 I(T?)RS.
Total weight of the front wheel assembly is just under 2 kg.
Thank you for explanation.
