mwkeefer
Hello All,
I'm about to test a theory I have about seriously cooling controllers for eBikes (and probably killing an IRFB4110 EB809 at the same time).
After testing the dielectric properties (don't ask) of several synthetic motor oils, then testing them against things like epoxy I've used to anchor some components (100v caps, etc) for corrosive action and after all has gone surprising well... I have replaced the end gaskets which these units come equipped with with (of all things) blank Header Gasket Metal / Cork cut to fit and then some to ensure a fair seal.
Finally I didn't want to mold the wiring passing through the controller yet to water proof and make it leak proof so I've just run it upside down - all the OIL I'm using (off the shelf, expensive synthetic) was added through a tapped screw hole /. filler hole next to the wire loom and I've filled it to about 96% which en covers the entire PCB, the FET RAIL, etc.
So far (it's RAINING, Damn IT) things seem well, I've applied power, turned on ignition and thrown it on a GNG Gen2 BB Drive Dahon on the Bench and spun things up but I can't go out and load test it.... Even when I can, the G2 BB drive can't really handle too much power but the next step is to run it at 18S (10G loop on second 330 resistor to engage it - this enabled dynamic change from 10-12S into 13S-20S operations...)
Thought I'd test it on the BB Mount first because I use quite a lot of partial throttle and have some base temperature readings for them in various ambient temperatures so I can compare new model (enhanced) to existing specs - I would hope to see the controller appear to run hotter at the case indicating better thermal dissipation.
If this all goes well I will be having CNC machined, re-designed enclosures for all the popular xie chang controllers, lyen's PCBs, Methods controllers. First batch will be 6S and 12S and available for EB8 PCB, EB2 PCB and the newest EB3 series PCBs.
With how I have my CNC machine work done, if you need a custom enclosure (providing this hold up as intended) I will take shipment of custom controllers and design custom enclosures for the PCB / Heat Transfer Bus and return the controller with the PCB mounted and tested in the new CNC liquid cooled controller.
Anyone have some thoughts?
-Mike
-Mike
