CONTROLLER EPOXY WATERPROOFING JOB
Republic of Ireland.
I have heard tell of using "EPOXY" to waterproof these controller internals.
Has anyone else done this?
And what is the best "EPOXY" to use.
Over here we have a real problem with rain and puddles and what not......so if I can do this it would eliminate one major source of trouble.
Thanks.
are you saying fill it with apoxy?
all you really need to do is use clear silicon on the case ends and wiring coming out and the screws on the side that holds the aluminum bar for the fets.
that way you can crack it open if it ever needs servicing. :wink:
potting the complete controller is not recommended. but you can if you want.
I think that is what happened here...check this out......
http://www.youtube.com/profile?user=ampdavolts#p/u/16/zQk21G1QfuU
johnrobholmes said:
"potting" epoxy is the stuff you need. It doesn't shrink and destroy everything as it dries.
Cheers.
Do you have experience of this kind of procedure?
I might practice on some cheap controllers first, and put my findings here.
there are also things called "CONFORMAL COATINGS". these can be either spray on or dips. they are designed for this purpose. some can be cleaned using solvents to allow board repair. epoxy usually does not.
try a forum search. the topic has been previously discussed. various products were mentioned and tried. might be easier to revive one of the old threads before starting a new one.
rick
I pot up stuff all the time for R/C use. Don't do it to something you value, if one component dies it turns into a paperweight :lol:
Conformal coatings are a better idea in the long run.
I use this silicone conformal coating on the boat controllers: http://cgi.ebay.co.uk/ELECTROLUBE-DCA-SILICONE-RESIN-CONFORMAL-COATING-200ML_W0QQitemZ230357947941QQcmdZViewItem?rvr_id=&rvr_id=&cguid=9a13470111d0a0e202874dc7ffd55255
This eBay supplier is as cheap as any I've found. The stuff is easy enough to use, you spray on a couple of coats (leave a couple of hours between coats) and then gently cure it in an oven (after a few hours of air drying time). It completely seals the board up and will penetrate up the ends of the wires a bit as well, sealing them up. The downside of this is that the coating will penetrate under the FETs if they are not tightly screwed down to the heatsink and well sealed with heatsink compound, which could result in a poorer thermal path. Provided the FETs are fitted properly this isn't a problem. The heatsink bar needs to be cleaned up afterwards, or well masked off, otherwise the coating will restrict heat transfer.
The advantage of this type of coating is that the board is repairable. It's possible (but very smelly) to solder through the coating if you need to do any repairs. Obviously the board would need re-coating after repair, but this is better than just having to write the board off if a fault develops.
The epoxy coating illustrated in that video presents a potential problem for some types of controller. Many controllers use a big power resistor to drop the input voltage to the regulator. These can run pretty hot, so coating them in thick epoxy might not be a good idea. There are controllers on the market that are potted in resin, but some have proven to be highly unreliable. Tongxin sold/sell a tiny potted controller, but they fail because of local heating internally. Two that I've seen have had burnt areas around the current shunt, showing that the potting was acting as a good thermal insulating layer, to the detriment of reliability.
Jeremy
Thanks Jeremy for another helpful post!
I am definitely going to epoxy the cheap Cammy_CC controller, if it breaks, it don't matter I suppose, it's worth around €20 to begin with.
Thanks!
