Controller for 3T*22 QS 205 V3 45H 20' wheel for A2b Metro
Amiran
Hi,
I a newbie here. I have got A2B Metro with QS 205 H45 V3 (I could not crack-open the A2B Hub motor to install the better external controller... damaged the spoke flanges)
I have big 48V build going on 13s6P 4250mAh 20700 Sanyo's - capable of 90-100Ah continuous.
Motor is laced in 16 inch moto rim and heavy Heidenau tires.
I would be glad to hear recommendations for 150Ah controller with Bluetooth connectivity options.
Cheers
Welcome to the forum :)
To get most of that motor you might wanna consider going up to 72v. Or if that is not an option push more current.
Controllers well there are a few to choose from. I think a good match for the motor you got would be the Mobipus 72200. You can order this from ES member samD's website: https://ballaratebikes.com/collections/controllers/products/72v-200a-mobipus-foc-sine-wave-controller you also get the option to hook up a windows tablet to get a real cool dashboard with real time info on speed, amp, volt etc.
Also there is sabvaton 72200 look at the for sale section new, there are a few that sells those.
Also there is a new adaptto max-e controller coming any day now, specs are a little secret yet. The old version did not have blue tooth. Maybe the new will?
Hi macribs,
Thanks for your warm welcome and suggestion. Iwill look towards Mobipus for next build. I went towards cheaper option Kelly KLS6035s.
I hope I will be fine with amount of current it can supply.
Thanks
