Hey ,
I am trying to find a way to charge my 12Volt Solar System with my Ebike in order to do some workout while inside my house when i cant go outside for a ride and also having an alternative way to charge my battery bank when the weather is not good.
To the point now.In most of the ebikes out there if you don't have a battery pack connected and pedal you will see that your CA will come back and it will read some Voltage.I did this ones and i want to check it out and test it thoroughly and build a cheap generator.
I am using an MPPT controller as a battery charger for my 12 Volt bank and i was wondering if i can just connect the + and negative from my controller to it pedal and charge the battery.The controller can handle up to 24 Volts with no issue and it has a blocking sock diodes in the leads so its safe to connect the terminals in theory.
I am thinking on buying a heavy duty steel rear wheel stand that will enable me to pedal inside my house and ofc do the necessary cable arrangements.
Anyone done something like that ? having any tips or what not to do or anything ?
P.S.
I might also consider on taking one of this things if you think it will be safer.I can use the 24 volt as well http://viewitem.eim.ebay.gr/BATTERY-CHARGER-48V-to-12V-STEP-DOWN-DCDC-10AMP--120W/230619561393/item
Thanks mates
P.S.
Thanks mates
