jason72
1 W
Hello guys,
I'm looking for a cheap cycle analyst.
where can i find one?
sico said:They're bloody cheap for what they are really. 8)
jason72 said:Hello guys,
You can't. What makes you think you need one? What info do you want from it?jason72 said:Hello guys,
wesnewell said:You can't. What makes you think you need one? What info do you want from it?jason72 said:Hello guys,
It can provide the battery pack voltage, but afaik not the individual cell voltage. It can provide how far you've ridden, but not how much farther you can go, as that depends on unknowns like wind, terrain, and how heavy you get on the throttle. It can provides amp/watt usage and a governor to limit the usage. I put a few thousand miles on my first ebike with nothing but a $2 cycle computer for speed/distance/etc. and never hurt the lipo battery. Since over discharging was a concern, I eventually installed the HK-010 power analyzer. At $18.99 it was still more than I wanted to pay, but it does provide lots of info like battery voltage, real time amps/watts usage and watts used so far and has lots of other uses such as idividual cell checking and balancing for up to 6s bricks. Since going to 100V battery pack it sits on the desk for other uses. I now use a $3 digital vom hooked to the controller to monitor battery pack voltage and a $2 cycle computer for speeds/distances etc. And 99% of the time, the vom is rurned off. With my current battery packs I can go about 100 miles or more the way I ride most of the time. On my original 48v bike the person that now has it doesn't use anything except the controllers lvc to let him know that his battery is low. He then brings it to me to charge. The lowest he's run it down was to 4% charge when he pushed it for about all he could get. It's running 10ah of 12s lipo with lvc around 40-42V.jason72 said:wesnewell said:You can't. What makes you think you need one? What info do you want from it?jason72 said:Hello guys,
info: battery status/voltage status/km left with current battery status/km per hour speed status/
that's the basic.
Correct.wesnewell said:It can provide the battery pack voltage, but afaik not the individual cell voltage.
I have never used the HK-010, but I agree that it's a very good alternative, especially because of the built-in individual cell monitoring. However its practicality is very limited because it only support up to 6 cells (22.2V nominal).For those wanting something similar to the CA, The HK-010 power analyzer is a very good alternative at $18.99 from HK.
