Cycle Analyst DC Out Issues / Throttle Bug
izy
So I bought a 12-80v Light with a Halo/Main Beam toggle.
I was recommended it by another user with a CA bear in mind he doesnt use it directly on DC he uses it on a CA Shunt and 12V downstep.
Heres where it gets funky, the CA will power it perfectly fine no downstep
buuut for some strange reason it increases the throttle output voltage it sends to my phaserunner. which will actually cause the motor to throttle albeit minimally
My Phaserunner reads 1.20/1.21V before i plug in the light.
once i plug in the light the Phase reports 1.25-1.29V on the throttle output.
The analyst doesnt show me throttle active either result also happens when unplugged.
If I increase my CA output voltage and restart it with light. It increases the output ontop of whatever is set.
The CA also reports the light drawing 40W but my bms reports it drawing 20W
