Delete topic.
slowlane
(FEB !8, 2010. TOPIC SHOULD BE DELETED BY A MODERATOR, Robert.) I bought a used Strong Bicycle GTS210. Want to learn the hub motor specs,is it worthy of upgrading (to 400-500W @ 36V), and is it geared? Hub has a Z in a circle, circle is broken on right side, Z could be an N, Has serial DB66030327G. Frame spread is 175mm, overall diam. of hub is 129mm. Has 7 sproket cassette AND 180mm 6 bolt disc on left side.Contoller is tiny, BRUSHED 36V, 250W at 18A, 500W peak. http://www.strongbicycle.com site states they make 300 types of ebikes. English version is just a translate...sign up doesn't help. Thanks for your input. Robert.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=13255
Could it be the same motor I have?, see my post and picture...it has that Z or N in the broken circle on it...
Mine is a geared brushed. It is very good at 48 volts 800 watts, I've been running it for several months with no issues. Lots of torque.
