MarkerDave
- Joined
- Oct 30, 2020
- Messages
- 2
Derbi senda X-treme SM
Hello,
For my first project I plan on converting a 50CC Derbi senda X-treme SM to electric drivetrain.
The specifications that I aim for are 40 to 60 km of range on one charge, 10KW nominal power, top speed 120Km/h,
regenerative braking, everything aircooled and trying to keep the weight below 150KG.
Also this bike has to be streetlegal because I want to use it as a commuter bike.
Currently the project is in the early planning stages like figuring out which motor to get and how big of a batterypack could fit within the frame that is being used for this project without cutting or welding anything on the frame.
Here is a list of parts that I plan on using for this project:
Controller: ASI BAC 4000, because this controller is compact and can handle enought power for what I want.
Battery: 72V capable of 200+Amps, 20s13P 18650 pack, using cells that can handle a discharge current of atleast 20A.
Motor: QS 138 90H, Denzel D9000 or Motenergy ME1718.
I am still doing some research about these motors but for now I have read good things about the QS 138 70H that looks similar to the 90H, but I can't find much about the QS 138 90H.
The Denzel seems to be a bit of a hit or miss and for the Motenergy ME1718 I am unable to find any definitive specs or actual reviews.
Precharger: TBA
Contactor: TBA
Throttle:QS Z6 throttle looks good
BMS: should be able to handle 20 cells and 300A - 400A. AntBMS or Daly bms looks promissing,
need to do a little bit more research before I decide which one to get.
The bike before it was taken apart
Hello,
Precharger: TBA
Contactor: TBA
