EMF said:
auddog007 said:
In looking over my options, I came across this website for a 12 cell pack - http://www.tppacks.com/proddetail.asp?prod=Battery%2DPack%2DKit - Has anyone worked with or would recommended this type of setup. I've looked at this several times as it appears to be an easy way to make a pack.
I think Gary Goodrum has. :wink: There are posts about the kit in the care and feeding of A123 thread I believe. He supplies the kits and that is his website. It was a good idea and he tells about the pros and cons.
Yes, I think I have seen that...
I originally did that 12-cell kit for use in some of the RC helicopters that the normal styled packs wouldn't fi in, but I have used it recently to build some packs for the folding bike shown in my avatar. I started by doing to 16s versions and then sticking them side-by-side. Here's what they look like:
I now have some extra-wide 9-1/4" heavy duty shrink wrap so now three of these 16 cell "sticks" can fit side-by-side. Here's a shot of my folder with one of these 48-cell packs, with a 32-cell version on top:
These are simply five 16s strings that I connect together in parallel, for a 16s5p configuration. These have no balancer wires brought out, just the individual main leads for all five strings. For the most part, I just charge them all together, as one big pack, but occasionally, I check the voltage level of each string, and will sometimes charge each of the strings separately. For the most part, they all remain pretty well balanced and all have fully charged "resting" voltages of around 57.5-58.0V. Originally I had two 16s2p packs and one lone 16s1p "stick" that I used as an extra, for longer range. I noticed one of the strings had a resting voltage that had dropped to about 55.5V, so I opened up the pack and checked. I had one block of four cells that were at 3.35-3.50V, and the rest were up over 3.6V. I balanced all the cells and did a few cycles on the whole string, to make sure the cells were okay and then I built the the 3-string pack shown in the picture.
This is all temporary, so I keep my eye on the overall voltages, and try not to run this setup down too far. Usually my wife rides this bike and I usually don't have to put more than about 4-5 Ah back in after one of our typical 8-10 mile rides.
It has been my intention to do an ebike-specific a123 kit, or series of kits, but I've been struggling with trying to find the best format that doesn't take a week to build. My first atempt was here:
This used four 10-cell packs, pretty much just how they come out of the DeWalt packs, stuck together. There was a hand-wired balancing harness that brught out the connections which could be used with a standard RC-typ balancer, like the TP-210V shown. These connections could also be used with the 10-cell LVC protection boards.
The wiring harness took forever to make, so I know this wouldn't wrk as a "kit", so I did a new board that combined the wiring crossover connections with the LVC circuits, which simplified everything quite a bit, and got it all into the pack:
Two of the boards are used, but only one needs to be populated with the LVC parts. The balancer plugs from the DeWalt electronics module are cutoff and soldered onto the boards. Besides the main power leads, the balancer plugs are brought out as is a small two-wire JST plug for the brake inhibit signal.
I'm now using two of these 10s4p packs in series on my other folding bike, shown here in the middle:
Although I'm pretty happy with the 20s4p setup, I'm still not crazy about how this would do as a kit. I'm also not so crazy about the form factor, and about having to use the plastic end cases from the DeWalt packs which simply add bulk and weight, and don't really save all that much in assembly time. Plus, the packs are a bit "lumpier" than the clean-looking "stick" packs.
Instead, what I've decided to do is to go back to the inline format and make new boards for between the cells that will serve multiple purposes. They will have contacts for the cells, all the required interconnects, and the LVC circuits built-in. I'm think of doing two configurations, one that is 12s4p (40V/9.2Ah...), that can be used in existing 36V and 72V setups, and a 16s3p configuration that will be good for 48V setups.
More on all this later...
-- Gary
