steelefist
1 W
- Joined
- May 27, 2008
- Messages
- 62
I've just finished modifying a new scooter, but having a major problem getting the thing going!!! it's so frustrating to because everything is ready to go.......
The system I am using is a 750 Watt 36 Volt MY1020 motor run at 48 Volts using forty 1.2V 14Ah F-size NiMh Cells.
The power pack seems to be fine and fully charged. The motor runs fine when tested at 36V with the original 36V controller.
I then bought an LB-37 48V controller from TNC Scooters. Wired it all in correctly and immediately when i completed the circuit by attaching the final wire..... the batteries were shorted for a couple of seconds before i detached the wires. I checked all the wiring and kept the system to the minimum of the motor, the throttle and the speed controller.....
....Again the batteries were shorted, this time blowing a fuse I put in the circuit.
So, after inspecting it I thought it must be the controller! I ordered a new one, a better, bigger and more sturdy (Model YK42-4) Yi-Yun, which also runs on 48V with a greater current handling capability.
Again, popped the fuse straight away. The sparks are clearly from a short circuit current. So far I have blown two 10A, one 15A, one 20A and a 35Amp fuse. I cannot see anything wrong at all. The throttle seems fine, the motor, the cables, there is no frame contact from any terminals.
Everything seems absolutly fine, yet the batteries keep shorting out...
Any help or advice, theories or possible causes would be appreciated...
