Whats the reasoning behind doing a metal battery housing/casing(like your regular AA Primary battery "Non-Rechargable")
And using the "Pouches" with tabs.
I see the Headway batteries have screw ends, then its an easy DIY project, with the metal tabs, orange house. I have yet to see a bolt to screw into the ends.
Then for the other style of metal house, you need to spot weld them using metal ?sheets?, or use a 100W soldering iron with heavy big tip.
What about the pouches how are you suppose to connect the pouches?
So the reason why LiFePO4 battery packages have different discharge rates C-rate cont and max/Acont. and Amax is because each cell type, whether it be 38120S, 38120HP, 38140S or 40152 cells (Cells Headway Headquarters sells), have different discharge capabilities. The numbers denote physical size. Headyway has higher prices even for their DIY kits. But they are American.
38120S states 3C/10C
38120HP, 10C/25C
38140S 3C/10C
40152S 3C/10C
Then I see on BMS Battery for their LiFePO4 batteries discharge rates from 15A/30A, 30A/60A and 50A/100A. I dig deeper into their cell only page.
38120S (10C=120Acontmax 15C=180Amax) 10Ah
38140S similar different Ah, 12 Ah
5Ah 6665143 Li-NiCoMn Polymer Battery Cell - 1C=5Acont, 2C-10Amax (POUCH)
LiFePO4 Battery 7070260 Polymer Cell - 9-10Ah, 1Ccont 2Cmax (POUCH)
40152S - 15Ah 10C=150Acont 15C=225Amax
High C-Rate 10Ah Li-NiCoMn Li-Ion Cells - 5C=50Acont 10C=100Amax (POUCH)
missing High C-Rate 15Ah Li-NiCoMn Li-Ion Cells 5C=75Acont, 10C=150Amax (POUCH)
missing High C-Rate 10Ah Li-NiCoMn Li-Ion Cells 5C=50Acont, 10C=100Amax (POUCH)
Panasonic High Capacity 18650 Battery Cell NCR18650PF - 2.9Ah - 10Acont.
Lithium Ion Battery 18650 Battery Cell 2200mAh - 18650 Battery Cell - Model: N18650 - Max.Constant Dicharge Current: 4.4A - Chemical: Ni-Co-Mn
2500mAh Lithium Ion Battery 18650 Battery Cell - Lithium Ion Battery 18650 Battery Cell - Model: 18650F5 - Max.Constant Dicharge Current: 5A - Chemical: Ni-Co-Mn
LiFePO4 Battery Cell - Model: 8760153 - 5.2Ah - Max.Constant Dicharge Current: 10A - Chemical: LiFePO4 (POUCH)
SANYO NCR18650GA 3450mAH Lithiun-Ion Battery Cell - 3.6V - Continuous Discharging Current (Max.): 10A
So if LiFePO4 is Lithium-Ion, I assume thats the "Li", which is the chemistry of the battery itself. Then I wonder about NiCoMn, what is that exactly?
Im just guessing, Nickel Cromium Managanese? I was close.....its actually Nickel Cobalt Manganese
This thread pops up, Title - LI-ion NiCoMn Battery from BMSBattery
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=33566 which I will read no doubt.
1
liveforphysics said:
SamTexas said:
Rassy said:
It is only rated at 1C continuous, ...
That's strange. Most Nickel Cobalt Manganese cells have a 5c continuous and 10c burst rating.
1C continuous is usually for 18650 LiCo cells.
Any NMC cell in 18650 was made for a laptop, not an EV. It's going to have very little material in it to improve conductivity.
