Uncle Ron
Spheroids,
A post by Papa on another thread reminded me of something that I've been curious about and wonder if any one(s) can shed some light?
First I'm wondering whether Papa is just ignoring the differential thingy in his build, whether he's using two controllers or a double (dual) controller and just what will be the results in terms of turning at various rates depending on how the trike is set up.
I'm sure I read somewhere here that there are double controllers that can handle two hub motors from a single box, or is my certainty misplaced? If there are such devices, how relatively easy or difficult would it be to initiate an electronic differential controlled by a steering sensor such that power to the inside wheel of a two wheel drive trike would be reduced appropriately on a turn of any radius? This could apply to 2 wheel rear drive on a delta or 2 wheel front drive on a tadpole trike. I don't have the skills or knowledge to answer this question, but it seems like, in my defective mind, that it would be a relatively simple dual controller modification. If it's possible, this would be a far easier and lighter version of 2 wheel trike drive, than moding a trike with a motorcycle trike differential as BLUESTREAK has done?
Papa, if you see this, what is a stub shaft, how does it work, where do you get one, and can it be installed without machining? Quite a question, eh?
Papa said:Had I not already sprung for a GM mini, I'd be whipping out the plastic. Still unlaced, the 'mini' sits on my bench in pieces, awaiting a stub shaft for single sided mounting. If all goes as planned, I'll pair this little guy with another and bolt them on the rear of a delta trike. No comment on the 'single' controller for both... yetRussell said:Who will be the first to try these little cuties? I'd like to see dual cute motor packages run by a single controller 8)![]()
With the frame still in the jig and parts strewn all over the floor, it's a safe bet it won't see asphalt 'till spring.
