Hi,
I've been trying to put together a hub motor setup based around this controller...
Bafang CR A101
I'm also using the following Bafang components...
DP E160 display
SR PA121 bottom bracket sensor
The motor is not Bafang it's a Aikema 100SX (250w 36v)
The battery is generic
The problems I'm having:
-Turning the pedals does not operate the motor at all.
-If I put the bike into walk assist, the motor will operate properly for about 2 seconds before I get an error 21 message (speed sensor error)
I have bought a cheap multiboard Canable and hooked it up with Bafang Canable Pro...
-The sensor data shows the correct cadence readings, but nothing for torque
-If I do a speed sensor calibration the motor revs up for about two seconds before I get an error 21 and it shuts off.
-I tried fiddling with a few of the motor settings, didn't change any behaviour.
Any help much appreciated - I'm afraid I'm in way over my head!
Bafang CR A101
DP E160 display
