Rawkkrawler
Requesting some DIY advice from the experts. I asked a similar question already, and another member had some great responses. But I'm now looking to dig a bit deeper.
Purchased to identical scooters, both using 52 Volt 14S9P batteries. Both only charged to 55ish volts. A few packs were out of balance of course.
I was successfully able to get one battery to balance, and repeatably hold a balance across all 14 packs. Unfortunately the range is terrible, and i drop equally across all packs down to 55 volts. From the other member here, he suggested that i have a capacity issue. Battery is 2 years old, with 100 miles on the scooter itself.
So the question to you all, how would a DIY a load test on the assembled battery across each pack without removing the nickel strips? Using some electrical knowledge with ohms law, and 7 parallel batteries in a pack, at 2500ma each, it appears a 1 ohm resistor could "safely" drop the voltage so I can plot the decline of the pack. I guess what I'm looking for is a comparative chart across all 14 packs to find the smoking gun. Also, is it possible that one bad pack, or a cell within that pack, be effectively dragging the overall battery voltage (14 cell packs) down evenly? Or the obvious question, how does a pack that stays balanced within .02 volts drain so fast.
Anyway, that's where I'm at. Appreciate any assistance you provide.
Mike
Mike
