Iron Yeti
My boss is an electrician and gave me a crash course in electrical properties today. So just to make sure I have this straight I would like to propose this to you folks.
I am going to buy the X-504 model. The main reason is here in Northwestern Connecticut there are tons of hills and I need the torque to climb aforementioned hills. So, first question. Along with the X-504 can I use the Series 4 '20A(36V-72V) DUAL SPEED CONTROLLER with Cruise Control Input. (Instant Start)'
http://www.poweridestore.com/Brushless-Controllers/Series-4-Controllers/20A36V-72V-DUAL-SPEED-CONTROLLER-Instant-Start-with-Cruise-C
Will this work since I am running 36V/20Ah or will the controller not work with the newer series motor?
Along with this my plan is to buy a set of 22 LiFeP04 batteries rated at 3.3V/10Ah and doing 11x2 series and 2x parallel 36.3/20Ah (I don't know if I wrote that right, haha).
At 750W for the X-504 using a 36V battery the motor is going to be drawing 20Ah (750/36=20Ah) So, 36V/20Ah will last me about an hour at maximum speed with no pedaling. Pedal to the metal the motor will be running at about 24Mph meaning that if the battery can output 20A, in one hour the battery will depleted, so I can travel about 15-20 miles on a charge taking into account hills, friction, weight, etc. Is this correct?
My last question is. If the controller I plan to buy is rated at 36-72V/20Ah I can later on add a second 36V/20Ah battery pack for longer distances with no issues, correct?
Thanks.
Thanks.
