it is indeed quite dangerous, to the point where i might had a second brake switch on my front hydraulic brake, here is why:
- in order to install an e-brake on a hydraulic line, you need to buy a small kit from Magura. You cut your line and insert this switch on the line, when it detects pressure, it enables regen.
- if ever my hydraulic line fails and start to leak a lot, because i opened it and did not rebuilt it properly, then i loose my rear brake, both regen braking and mechnical braking. And i cannot stop the cruise mode if it was activated. So i'm left with my front brake only. Depeding on the speed i'm riding at, could be tricky to bring the bike to a stop.
- Agreed the probability this happens is low, but the consequences are quite bad.
Actually i had the controller stuck at two occasions. Nothing was responding , ebrakes, throttle, nothing. The hub was just spinning. The only way was to switch off the controller. Luckily i was not going to fast and there were no obstacles ahead. I managed to slow down a bit by braking at the back and with one hand to find the controller switch. But if this happened in a difficult road, could have been tricky. So i'm thinking of adding a kill switch near my handle bar. I'll try to extend the wires of the main switch of the controller and bring it to my handlebar on a switch. We'll see,
