Darren2018
- Joined
- Aug 18, 2018
- Messages
- 234
Does a BMS actually unbalance a pack via it's own resistance? Let's say you had a perfectly balanced pack and then you added a BMS in series with it would the cell group that connected to the BMS become unbalanced? Also can someone who has actually built a perfectly balanced pack confirm if this procedure will work to build a perfect pack,
charge all the individual cells to exactly 4.2V and let them rest for a week or two then group them in relation to their self discharge
discharge each cell at the max load it will see when actually in the pack and log it's Ah's/Wh's/DCIR (repackr.com looks ideal)
arrange the cells into parallel groups with as little divergence as possible from every other group
weld them all together using equal lengths of copper to keep the resistance as close as possible between the groups
add in the BMS
load the pack with the max operating current and let it get to a reasonable temp similar to what it will see when in use and note the voltage drop in each group
if needed solder in some extra copper to which ever groups need it
I have one of those smart BMS's from GBK that you can calibrate yourself along with a reasonably accurate 6000 count meter but I was wondering if the BMS would be accurate enough to let the pack stay balanced (without balancing via the resistors) or would the software/balance IC gradually unbalance the pack due to it's own inaccuracies.
I'm still learning and I know this is not common procedure for building a battery but I am interested as this is going to be my first build and I really want to make it as good as possible.
add in the BMS
