electr0n said:
Something like that would be ideal but I don't want to spend much on the bike. I figure I should be able to find something, at the used bike shop. Anything more common with 135mm dropout width suitable for 20" wheels?
Don't sweat the dropout width-- that's easy to amend. Focus on getting a bike that fits you. Something designed for a four and a half foot child isn't it.
Look at it this way: You're going to spend many hundreds of dollars on batteries and motor, even though you can get AA penlight batteries for $0.50 each and electric hobby motors at Radio Shack for $5. Think of a department store bike, or a kidbike that's way too small, as the equivalent of the Radio Shack motor or the AA batteries. Yes, it's technically a bike and it doesn't cost much, but it's also wholly inadequate for what you're trying to accomplish.
If you can find a full-sized 24" BMX cruiser bike (
not a kidbike with 24" wheels) and it has a bottom bracket height of at least 12", then you can put a 20" rear wheel on it and still have plenty of ground clearance with normal cranks. You can have low but probably adequate ground clearance even if you swap both wheels for 20". It's easy to tell if the BB is high enough, because the axle of a 24" wheel is about 12" high. If the chainstay slopes uphill to the crank, then the BB is higher than 12".
In some cases, linear-pull brake bosses located for 24" wheels are usable as U-brake bosses on 20" wheels (a tall braking surface on the 20" rim makes this more likely). If that works out, you'll have to sleeve them up from 8mm to the 9mm diameter employed by U-brakes. If that doesn't work, you can chop them off and weld on new bosses, or attach a disc brake tab.
Chalo
